[GRASSLIST:1791] GRASS Mac OS X -- no d.mon
    otter
    otter at bestweb.net
    Sun Apr 29 23:12:01 EDT 2001
In the process of installing GRASS on Mac OS X . . . GRASS is now
running in an xterm window (Xtools), but have run into the following
problem:
When try to assign a monitor device, I get the following:
<PERMANENT> in Location <spearfish>
GRASS 5.0beta11 > d.mon start=x2
Sorry, </usr/local/grass5/dev/fifo.3a> not available
Have GRASS adminstrator check etc/monitorcap file
Can't stat /usr/local/grass5/dev/fifo.3a
Problem selecting x2. Will try once more
get same result for other values x3,x4, etc.
checking status with d.mon -L shows all displays as ??.
Following up, the error message, the /usr/local/grass5/dev directory is
empty.
In the /usr/local/grass5/etc directory there are both a monitorcap and a
monitorcap.orig file (which appear to be identical).
Sample info from monitorcap:
x0:driver/XDRIVER:X-windows graphics display: \
      /usr/local/grass5/dev/fifo.1a /usr/local/grass5/dev/fifo.1b \
      ::any terminal
x1:driver/XDRIVER:X-windows graphics display: \
      /usr/local/grass5/dev/fifo.2a /usr/local/grass5/dev/fifo.2b \
      ::any terminal
Any help appreciated.
Art
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20010429/1bec2217/attachment.bin
