[GRASSLIST:2253] Re: Printing postscript to a designjet
    Henk Coetzee
    henkc at geoscience.org.za
    Fri Aug  3 03:56:53 EDT 2001
Hi Lionel
On Thu 02 Aug 01 10:11, Lionel wrote:
> Le Mercredi  1 Août 2001 16:43, vous avez tappoté sur votre clavier :
> > I have just spent most of the afternoon fighting with a designjet 650,
> I spent several week with a dnj650C
That makes me feel better.
> The solution seems to be ghostscript with a ps to rtl transformation. RTL
> is a HP format that supports designjet with low memory (line by line
> transfert between the spool on your computer and the printer's spool). This
> operation is hight CPU cost.
The CPU cost is not a problem, the Windoze printer driver has the "in
computer" option, which does this.
> > Anybody had any more success?
> It's just an idea. The ps to RTL transformation worked, but I had a page
> offset (X and Y) problem, and ghostscript's documentation is so difficult
> to read that I've never find the solution. Now we use the HP jetdirect
> utility on a Win2000 box. I've never tried jetdirect on Linux but I know
> that it exists.
Jetdirect on linux was also a mystery, until we found (without much
struggling) that a Jetdirect port looks like a normal un*x spool queue.
Basically, it will print whatever you throw at it.
Cheers
Henk
