[GRASSLIST:2299] Re: Import questions
Roderick A. Anderson raanders at tincan.org
Tue Aug 7 12:29:48 EDT 2001
On Tue, 7 Aug 2001, Rich Shepard wrote:
>   Actually, what I'm planning (and hope to be able to implement toward the
> end of this year) is to build a small, rack-mounted system of 1U
> twin-Athlon CPU, SCSI drive Beowulf cluster. Probably 8 processors to start.
> That will be devoted to GRASS, models and other number crunching.
Cool.  Can GRASS run in a parallel processor environment?  I'm mostly a
loyal roadie (roady?) to GRASS rather than a user.  Got to get more time
to play and explore.  I've been a fan for so long I actually have
hardcopies of GRASS Clippings.
Cheers,
Rod
                 Remove the word 'try' from your vocabulary ...
                     Don't try.  Do it or don't do it ...
                                Steers try!
                                                            Don Aslett
