[GRASSLIST:2317] Re: gis_set.tcl help!!
Kevin Slover
kjslover at nhc.noaa.gov
Wed Aug 8 09:51:50 EDT 2001
Antonio, I had the same problem when I started off with GRASS5, and
actually, I was able to force it to start in text format using GRASS5
-text.
Glynn Clements wrote:
> António Torres wrote:
> > I'm using grass5 and when the welcome dialog box opened i choosed
> > create a new region but i wrote nothing in the location nor dataset.
> > Now when i run grass5 command all that appears is the box of
> > gis_set.tcl error.
> > What i need to do?
> rm ~/.grassrc5
> Glynn Clements <glynn.clements at virgin.net>
