[GRASSLIST:2320] Problem compiling GRASS5pre1 on Mandrake 8.0
    Steve Trick
    TrickSG1 at Cardiff.ac.uk
    Wed Aug  8 12:39:03 EDT 2001
Dear Grasslisters,
I am having some problems compiling GRASS5.0pre1 on my Linux box
which is running Mandrake 8.0:
When I am at the 'configure' stage of installation the script reports that
it is having problems finding the zlibs.  This still occurs even when I
point the configure script to where the libraries appear to be on my
system - /usr/lib/.  It also has the same problem finding the TIFF
libraries.
I then go on to have problems when I run 'make'.  I see the following
error when each module is compiled:
/usr/bin/ld: cannot find -lz
collect2: ld returned 1 exit status
make[1]: *** [/opt/grass5sources/grass5.0.0pre1/dist.i686-pc-linux-
gnu/etc/front.end] Error 1
make[1]: Leaving directory
`/opt/grass5sources/grass5.0.0pre1/src/front.end'
GISGEN failure at STEP: src/front.endG
I'm not a UNIX expert so I apologise if I am missing something
obvious!  Can anybody help?
Many thanks,
Steve
Steven Trick BA MSc
School of History and Archaeology
Cardiff University
PO Box 909
Cardiff
Wales
CF10 3XU
email: TrickSG1 at cf.ac.uk
Steven Trick BA MSc
Cardiff University
PO Box 909
Cardiff
Wales
CF10 3XU
mob: 07799897107
http://www.cardiff.ac.uk/hisar/people/st/
