[GRASSLIST:2324] Re: Removing a section of a raster map
Hal Mueller
hal at seanet.com
Wed Aug 8 17:50:06 EDT 2001
I haven't tried to do anything like this in a while, and might have
the details a bit off, don't have time to pin it down right now.
I think the key is r.mask. You can derive the mask by comparing
layer with protrusion to layer without protrusion. Or maybe just by
looking at layer without protrusion.
(hip shot, untested!)
I would try
r.mapcalc
to make a binary raster, 1 where I want data and 0 where I don't
r.mask
set the mask to be that binary I just made
r.mapcalc newrast=rastwithprotrusion
g.remove rast=MASK
d.rast newrast
should display a correct layer
make sure to g.remove the mask (or use r.mask to set no mask) before testing
your new layer; otherwise you might just _think_ you got it right
Hal
Hal Mueller hal at seanet.com
Mobile Geographics LLC http://www.mobilegeographics.com/
Seattle, Washington (206) 297-9575
Get CelestNav 2.2.2! http://www.mobilegeographics.com/celestnav/
