[GRASSLIST:2327] Re: Removing a section of a raster map
Rich Shepard
rshepard at appl-ecosys.com
Wed Aug 8 18:28:08 EDT 2001
On Wed, 8 Aug 2001, Hal Mueller wrote:
> hammer #1: try d.rast.edit on a copy of the data to try to generate a mask
OK. Haven't tried this.
> hammer #2: v.digit, using the original data as an underlying cell
> map, generate a polygon around the incorrect areas, build mask from
> that vector region
Tried this: the monitor window replaced the raster map with a boundary
entered into the v.digit set up. :-)
Hey! If it was easy, even I could do it.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-responsible mining happen.
