[GRASSLIST:2765] Re: compiling grass and gd includes
Glynn Clements
glynn.clements at virgin.net
Fri Dec 7 05:34:05 EST 2001
cmbarton wrote:
> Thanks again. Here is some info and a question. I hope that this helps
> with the configure script (as well as helping me compile grass).
> Here is the relevant section of config.log. It seems OK, but there may
> be something I am missing.
> -L/usr/lib conftest.c -lfftw 1>&5
> configure:7925: checking whether to use BLAS
> configure:8078: checking whether to use LAPACK
> configure:8231: checking whether to use Motif
> configure:8399: checking whether to use FreeType
> configure:8418: checking for location of FreeType includes
> configure:8444: checking for ft2build.h
> configure:8452: cc -E -traditional-cpp -I/sw/include -I/usr/include
> -I/sw/include conftest.c >/dev/null 2>conftest.out
> In file included from configure:8448:
> /sw/include/ft2build.h:55: freetype/config/ftheader.h: No such file or
> directory
This implies that FreeType isn't installed correctly.
The directory in which ft2build.h resides should also contain a
subdirectory called "freetype". In turn, that subdirectory should
contain several freetype headers, plus subdirectories called "cache",
"config" and "internal":
$ ls -R /usr/X11R6/include/freetype2
/usr/X11R6/include/freetype2:
freetype/ ft2build.h
/usr/X11R6/include/freetype2/freetype:
cache/ ftcache.h ftlist.h ftnames.h ftsynth.h t1tables.h
config/ fterrors.h ftmac.h ftoutln.h ftsystem.h ttnameid.h
freetype.h ftglyph.h ftmm.h ftrender.h fttypes.h tttables.h
ftbbox.h ftimage.h ftmodule.h ftsnames.h internal/ tttags.h
/usr/X11R6/include/freetype2/freetype/cache:
ftcchunk.h ftcglyph.h ftcimage.h ftcmanag.h ftcsbits.h ftlru.h
/usr/X11R6/include/freetype2/freetype/config:
ftbuild.h ftconfig.h ftheader.h ftmodule.h ftoption.h
/usr/X11R6/include/freetype2/freetype/internal:
autohint.h ftcalc.h ftmemory.h pcftypes.h t1errors.h tterrors.h
cfferrs.h ftdebug.h ftobjs.h psaux.h t1types.h tttypes.h
cfftypes.h ftdriver.h ftstream.h psnames.h t2errors.h
fnttypes.h ftextend.h internal.h sfnt.h t2types.h
> >> Also, I have had to put in --without-blas and --without-lapack.
> > That *is* a bug in configure; these were meant to be off by default
> > (along with freetype and motif). I've committed a fix to CVS.
> So I should just ./configure with all turned off -- including freetype?
Yes. You can use --without-blas and --without-lapack with no loss of
functionality. --without-freetype only disables d.text.freetype, and
--without-motif only disables xganim.
> > Note: If an argument is passed to --with-gdal, it should be the path
> > to the "gdal-config" script, e.g. "--with-gdal=/sw/bin/gdal-config".
> I had to use the precompiled binary of gdal for OSX. It only comes with
> a dynamic library (libgdal.1.1.dylib). No gdal-config.
What about headers (gdal.h, cpl_*.h)? Although, it appears that
r.in.gdal will compile without them when not using --with-gdal.
> Should I let the configure script default to without gdal?
At present, r.in.gdal is always included in the build. --with-gdal
simply tries to link it to libgdal at build time. Without this switch,
r.in.gdal will attempt to load it via dlopen(). This will probably
fail on MacOSX; the code expects the library to have one of the
following names:
libgdal.1.1.so
gdal.1.0.so
gdal.so.1.0
libgdal.so.1
If you need r.in.gdal, I'd suggest editing the file src/CMD/head/head
after running "configure" but before running "make". But, AFAICT, this
approach requires the GDAL headers to be installed.
Glynn Clements <glynn.clements at virgin.net>
