[GRASSLIST:2769] Re: ps.map, grid line spacing
Glynn Clements glynn.clements at virgin.net
Fri Dec 7 10:15:16 EST 2001
ulf at mail.zmt.uni-bremen.de wrote:
> I'm trying to print a map with ps.map which should contain a raster
> image and a coordinate grid. Unfortunately, it seems to be only
> possible to space the grid lines by one degree in a lat/long
> coordinate system -- at least I tried "grid 0.01" as well as something
> like "grid 0:01:00.000" without success. Is there a possibility to get
> a more fine-grained grid resolution?
ps.map's "grid" command only accepts integer grid spacings.
You could try using an X-Y coordinate system, with units of minutes,
100ths of a degree or whatever.
Glynn Clements <glynn.clements at virgin.net>
