[GRASSLIST:2801] r.in.tiff
ulf at mail.zmt.uni-bremen.de
Tue Dec 18 17:34:29 EST 2001
Trying to import a greyscale TIF file (24 bit colour depth), I get the
following message:
GRASS:~/daten/gis/grass > r.in.tiff input=BANDA1.TIF output=band1
ERROR: Only handle 1-channel gray scale or 3-channel color. Try -f switch.
Anyway, r.in.tiff does not accept a "-f" switch (does it come from an
internally used r.in.bin?). What are your recommendations in respect
to this error?
The TIF file originates from a satellit image in a particular format
but was extracted using a utility coming with the image. In theory, I
also could use the original files (1 byte per pixel, 3200 rows, 3520
lines, 512 byte header). Do I have to cut the header of 512 byte with
a self-made program to use r.in.bin, or is there another import
facility I could use?
Many thanks for your help, Ulf
Ulf Mehlig <ulf.mehlig at zmt.uni-bremen.de>
Center for Tropical Marine Ecology/ZMT, Bremen, Germany
