[GRASSLIST:1438] Re: Converting surveyor's data
Rich Shepard
rshepard at appl-ecosys.com
Sat Feb 10 20:39:22 EST 2001
On Sat, 10 Feb 2001, Eric G . Miller wrote:
> However, if you can translate everything to points in space (rather than
> bearing/azimuth) than I think maybe v.transform would be sufficient.
> If there's some kind of way to tag the reference points to real world
> coordinates from whatever file formats are provided, then I'm sure a
> script could be worked up to build a vector line layer.
Eric,
These two sentences frame the problem exactly: translating a distance and
direction from a known georeferenced point to another georeferenced point.
Then taking the distance/bearing to the next point and georeferencing that.
Sure, once all the nodes are georeferenced the rest is easy. But, it's the
georeferencing step to which I referred. I infer from your answer that no
one on the list has looked into this. Guess it's research time for ol' Rich
in the Land of Geodesy.
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
