[GRASSLIST:1486] Re: import vector
Rich Shepard
rshepard at appl-ecosys.com
Wed Feb 21 09:56:59 EST 2001
On Wed, 21 Feb 2001, Gaetan GUYODO wrote:
> I have MapInfo vector files to import into GRASS, but these files are not
> .mid/.mif files :
> I have .cap .dat .id .map and .tab files
Gaetan,
None. The .dat, .id, .map and .tab are the four native format files in
which MI keeps objects and attributes. The .cap file is apparently specific
to that data set.
What you need to do (or have done for you) is open that table, then export
the files. You'll then end up with the base name (or whatever name you gave
it) and the extensions .mif and .mid. These are both ASCII text files. The
former has all the information on the graphic objects, the latter holds the
attributes (if any) for each object. The two files are related by a
one-to-one relationship of .mid row to .mif object.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
