[GRASSLIST:1338] TR: LOCATION_NAME not set
Pascal SIMON
ps at afico.ch
Fri Jan 5 06:02:12 EST 2001
Had EXACTLY the same problem !
Just start GRASS with -text option ! You'll have the console mode in front
of you !
The command is:
grass5 -text
I found it after long hours of patience !!!
As beginner with grass, I'm looking forward to experience more than starting
the soft !
Best regards
Pascal
Pascal SIMON
Institut d'Archéologie et d'Histoire Ancienne
Ecole Suisse
Université de Lausanne
BFSH2 - 1015 DORIGNY
E-Mail: pascal.simon at iaha.unil.ch
Tel. +41 21 692 30 47
Mobile. +41 78 600 69 42
ICQ. 62975304
> -----Message d'origine-----
> De : owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]De la
> part de Graham Smith
> Envoyé : dimanche, 31. décembre 2000 17:44
> À : grasslist at baylor.edu
> Cc : myotis at cix.compulink.co.uk
> Objet : [GRASSLIST:1326] LOCATION_NAME not set
> I wonder if someone can help me.
> I have just installed Mandrake 7.2 for the express purpose of learning
> Grass. I have also installed Grass5 beta10 and am having a problem
> running Grass.
> Running the command "grass5" gives a response Grass starting....
> A partial TCLTK window opens, but nothing else, and the command line
> stays with the Grass starting.... Message.
> I have tried launching Grass by
> Grass5 /home/gms/grassdata/leics/PERMANENT
> In this instance Grass runs and the full menu bar of TCLTK opens with a
> header "TCLTK 3.1 (2000) - location:leics" but if I try and do anything
> I get an error message LOCATION_NAME not set
> I have made my way through a whole collection of g. Commands but all
> respond the same way by saying LOCATION_NAME not set.
> Can anyone one suggest an obvious solution. I should point out that my
> experience of Linux is all of three days and I have described the sum
> total of my Grass experience. I would however, be very appreciative for
> some help in getting started.
> Many thanks,
> Cheers,
> Graham S
