[GRASSLIST:1358] Re: Web Mapping
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jan 12 14:10:53 EST 2001
On Fri, Jan 12, 2001 at 02:05:28PM +0100, Andreas Lange wrote:
> > What does happen if 2 processes try to access the ressource
> > D_cell at the same time ?
> That should never be done. Even if it does not crash it will not produce
> anything reasonable.
> One setup would be to use a temporary mapset within the current location
> for each process to avoid this. Or the CELL code could be modified to
> use a name from an exported variable (see HTMLMAP code how this can be
> done).
A small addition: You could analyse "grasslinks" how this management with
temporal datasets is done. Currently it is not fully set up here run, but if
GRASS would be properly installed on our *web server*, it would do:
Get it here:
http://www.geog.uni-hannover.de/grasslinks/
> And not to forget: last time i examined the CELL driver in
> GRASS5.0beta10 it was broken somehow. Had no time to find the problem.
I just generated some images - they looked o.k. But there will be a problem
at least with 24bit color table etc.
Markus
