[GRASSLIST:1387] Re: problems connecting to database via odbc &
v.reclass.pg problems
mlennert at club.worldonline.be
Tue Jan 23 06:32:13 EST 2001
It is a problem between Postgres and ODBC since DataManager doesn't work. I've
looked into the postmaster -i problem, but debian seems to handle this
differently via a postmaster.init file, in which there is a variable
PGALLOWTCPIP=yes. I've tried stopping the postmaster and restarting it by
simply typing postmaster -i, but this didn't change anything.
But I guess this is too far off-topic. I'll try to find the solution in the
Postgres / Debian mailing lists...
As to the postgres modules, they are great, but there still seems to be an
inconsisteny in the v.reclass.pg html-page. In the text, sql queries are
mentioned, but in the "synopsis" section the keyword is 'pql'. Then in the
description of the keywords, no mention of pql, but of sql. In the example,
the same problem again:
"v.reclass.pg sql=vect.sql key=tlid input=t.roads.pg output=t.roads.12
vect.pql: retrieve unique (t.tlid,t.cfcc) from t in type1
where cfcc ~ "A1"
sort by tlid"
So, if someone could explain, what I should use, sql or pql...
Also, I do not find the explanation of the 'where' parameter very clear. How
should this be formulated exactly ? And if I understand correctly, I can only
extract one set of data if I use this option, i.e. I can only create one
category.
I find the odbc reclass much easier to use, but this might just be my lack of
understanding of v.reclass.pg
More generally, I like the idea of having one interface (odbc) which I can use
in several programs, such as Grass, R, etc...
Moritz
Radim.Blazek at dhv.cz said:
> he problem seems to be in the connection ODBC<->Postgres. Could you
> test your DSN with isql program or DataManager first?
> Radim
arne at waikato.ac.nz said:
> Hi Moritz,
> I am not really shure, but could it be, that you do not start postgres
> with the "-i" option?? It sounds like the error I had first starting
> with postgres... And another question, why don't you use the postgres
> module??
> Arne
> On 22-Jan-01 mlennert at club.worldonline.be wrote:
> > In db.tables, I get the following error message when trying to connect to a
> > postgres database via the odbc driver:
> > DBMI-ODBC driver error: SQLConnect():
> > [unixODBC]Could not connect to the server;
> > Could not connect to remote socket. (101)
> > What am I doing wrong ?
> > Moritz
> Arne Pallentin
> Department of Earth Sciences
> The University of Waikato
> Private Bag 3105
> Hamilton - New Zealand
> Ph.: +64-7-838 4024 ext. 6229
> Home: +64-7-856 7877
> Fax. +64-7-856 0115
> e-mail: arne at waikato.ac.nz
