[GRASSLIST:2056] Compiling grass5.0.0pre1 under Solaris 8???
Lawrence Houston
grass at boyd.geog.mcgill.ca
Wed Jul 4 20:21:14 EDT 2001
GRASS Users:
Having troubles compiling grass5.0.0pre1 under Solaris 8 (Intel) using
SUN's Companion (04/01). LIBGIS fails within error.c:
gcc -g -O2 -I/opt/sfw/include -I/opt/grass5/grass5.0.0pre1/src/include -I/usr/include -c error.c -o OBJ.i386-pc-solaris2.8/error.o
error.c: In function `G_fatal_error':
error.c:72: `__builtin_va_alist' undeclared (first use in this function)
error.c:72: (Each undeclared identifier is reported only once
error.c:72: for each function it appears in.)
error.c: In function `G_warning':
error.c:87: `__builtin_va_alist' undeclared (first use in this function)
*** Error code 1
make: Fatal error: Command failed for target `OBJ.i386-pc-solaris2.8/error.o'
Any Ideas (4.3 for Solaris 7 Intel Binaries run under Solaris 8 Intel)?
Lawrence Houston - (grass at boyd.geog.mcgill.ca)
