Rich Shepard wrote: > Am I correct is assuming that the only way to visualize a DEM in 3D is via > nviz? You can perform static 3D renders using d.3d. If you want to be able to change the viewpoint interactively, you need to use nviz. -- Glynn Clements <glynn.clements at virgin.net>
