[GRASSLIST:1949] Re: Conversion of ER Mapper data
Rich Shepard rshepard at appl-ecosys.com
Mon Jun 11 22:27:49 EDT 2001
On Tue, 12 Jun 2001, Rod Paterson wrote:
>         Appended is an old Email containing some shell scripts that I wrote to
> allow the import/export of rasters between grass and ermapper. They were written
> for grass4.1.3 and the Unix version of ERMapper so your files should have a byte
> order of MSBfirst in the ERMapper header. If not then you could use 'dd' in the
> scripts to reorder bytes depending on whether you're dealing with integers or
> not.
> The scripts need updating for Grass5 to handle reals and null values etc
Rod,
  Thank you very much! I'll go get those files again and see if I can make
the scripts work with GRASS-5.
Much appreciated,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                  Making environmentally-resposible mining happen.
