[GRASSLIST:1953] Re: m.proj
Markus Neteler
neteler at geog.uni-hannover.de
Tue Jun 12 12:11:47 EDT 2001
Hi Morten,
(cc to "grass5" list)
On Mon, Jun 11, 2001 at 07:52:36PM +0200, Morten Sickel wrote:
> Hi,
> I have been using m.proj for a while to project GPS data from lat/lon to a
> local coordinate system. As far as I can see, the calculations are working,
> but the user interface is not the best one. I have been thinking about making
> a better UI for that module, that is:
> - Reading input and output files from the command line
> - Making a --help text
> - Reading projection information from the command line, maybe using a file
> similiar to arc/info projection files (The default ouput projection should
> be the location's projection)
> In addition, it should interface better to other grass modules. i.e the
> (default) output file should be directly readable by s.in.ascii.
that's great ideas! We would welcome this contribution. Maybe (later) the
projection description file could be generated from a tcl/tk window to
have a full GUI interface to m.proj.
> Before I start doing any serius work on this, I would like to know, Does
> anybody else do anyting similiar? (not as far as I can see in ONGOING) Or is
> anything coming that will replace m.proj?
At time m.proj is untouched and waiting for improvements. Related updates
will be the integration of the latest PROJ4 library including datum
transforms. But this doesn't affect m.proj too much (at least not the
proposed improvements).
> (Yes I know that I could make a lat/lon location and then use s.proj to pull
> the points over, but even with the current limitations on m.proj, I find this
> easier)
> Morten Sickel
> GIS consultant
> Drøbak, Norway
Perhaps you consider to switch over to "grass5" list for further details (if
required).
Regards and thanks in advance,
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
