[GRASSLIST:1971] Re: Command line
Roger S. Miller rgrmill at rt66.com
Mon Jun 18 11:14:39 EDT 2001
On Mon, 18 Jun 2001, [UNKNOWN] António Torres wrote:
> Hi all!!
> This is a very trivial question. How can i display the command line
> along with the tcltkgrass. When i run tcltkgrass i lost access to the
> comand line.
> what are wrong
When you start tcltkgrass from the command line, place an ampersand (&)
at the end of the command line.  That starts tcltkgrass in a separate
shell and leaves your existing command shell running.
Roger Miller
