[GRASSLIST:1546] Re: new location
Markus Neteler neteler at geog.uni-hannover.de
Thu Mar 1 14:01:27 EST 2001
Hi Gaetan,
[cc to Morten and Andreas]
an excellent map projections page is here:
http://www.geocities.com/mapref/prj/prj.html
-> France
You can find the Lambert II etendu there (written for
ARCInfo but easy to adapt).
On Thu, Mar 01, 2001 at 10:48:06AM +0100, Gaetan GUYODO wrote:
> Hello,
> I'm creating a Location/Mapset corresponding to my data, in the "Lambert II
> etendu" projection.
> I found some explanations about this projection, but I don't understand every
> question I have to answer to create this Location/Mapset.
> When I open grass, I choose "new location", with a new name.
Yes.
Other Projection coordinate system? (y/n) [y] y
Please enter a one line description for location <gaeton>
test
Please specify projection name
lcc
Please specify ellipsoid name
clark80
Do you want to specify a map datum for this location?(y/n) [n]
n
[it would be: Central Point/Datum: Croix du Panthéon, but this is missing in
 GRASS as far as I know)]
    Enter Central Parallel [lat_0] (23N) : 46:48N
    Enter First Standard Parallel [lat_1] (33N) : 45:53:56.108N
    Enter Second Standard Parallel [lat_2] (45N) : 47:41:45.652N
    Enter Central Meridian [lon_0] (96W) : 2:20:14.025E
    Enter plural form of units [meters]:  meters
> But in Lambert II etendu specifications, there are two others data :
> 	false easting (meters) : 600000
> 	false northing (meters) : 2200000
> Where can I specify these data ? I didn't find...
You are right - seems to be missing. We'll dig into this.
Thanks for notification!
> After, I have to define the default region : I'm not sure to understand.
> the default region correspond to the region which can be used for maps ?
> or it is only the default region displaied by the monitor... or another
> default region.
You have the "default region" which refers to the maximum region, and
the "current region" with are the current settings. Perferred settings
within the "default region" can be defined as "mapsets". Personally
I simply define location (="default region") and "mapset" identical,
but this is up to you. The current settings can be managed with
g.region, d.zoom etc.
Hope to have a solution for the false easting soon,
 Markus Neteler
