[GRASSLIST:1552] r.out.v5d
Ülle Straus starylle at ut.ee
Sun Mar 4 13:31:44 EST 2001
Hallo,
I am trying to convert grid3 sample-datafile CloudLCP.992172300 into
Vis5d with r3.out.v5d but i get the following error
> CloudLCP.992172300
<CloudLCP.992172300>
OPTION:   Name for v5d output file
     key: output
required: YES
enter option > proov.v5d
You have chosen:
  output=proov.v5d
Is this correct? (y/n) [y]
FLAG: Set the following flag?
Use map coordinates instead of xyz coordinates?(y/n) [n]
FATAL ERROR: G3d_getFloatRegion: error in G3d_getTilePtr
The same error occurs also with r3.out.ascii :(
What i did wrong?
Ylle Straus
student from the University of Tartu
Estonia
PS i am using Slackware 7.1 operating system
and GRASS 5.0beta11_2 from binary distribution
I consider to move over to RedHat 6.2, should I?
