[GRASSLIST:1575] Re: interpolate nominal values
    Bernhard Sturm
    sturm at datacomm.ch
    Thu Mar  8 11:17:07 EST 2001
At 16:29 08.03.01 +0100, Edzer J. Pebesma wrote:
> > I want to interpolate nominal data (soil types as point information).
> > Which possibilities do I have, what's the best method? -Any
> > experiences, suggestions?
>They're hard to interpolate. Nearest neighbour (forming thiessen polygon)
>seems
>a useful action; indicator simulation another one. Most interpolation methods
>are based on weighted averages, and are therefore only suitable to
>interval/ratio
but with the Thiessen Polygons you run into the trouble of producing
'plateaus' and 'canyons' between observed points... (which are hardly to
explain in the 'real' world) Thiessen seems to be a starting point of
understanding spatial interpolation, but it's not the end of the story.
According to my experience you can use other methods (Inverse Distance
works good for surprisingly many applications), but you have to understand
the mechanism of the interpolation model. Kriging is difficult to handle,
due to the variograms one has to estimate before running an interpolation.
For some application regularised splines with tension outperforms Kriging
and IDW quite well... but it really depends on the situation. (I only have
experience in precipitation interpolation, but not with soils...)
Bernhard
CDE, Centre for Development and Environment, University of Berne
the.sign
Bernhard Sturm
WebDesign & Software
Steinauweg 22
CH - 3007 Bern
fon: ++41 (0)31 371 83 21
fax: ++41 (0)31 371 83 21
mobil: ++41 (0)78 775 99 30
www.the-sign.ch
