[GRASSLIST:1616] Re: More projection problems...
mberglund
mberglund at rcinfo.net
Thu Mar 15 13:25:08 EST 2001
> I get exactly the same numbers 380339.35 1764858.00 using the same
> parameters you have (+ ellipsoid=wgs84)
I have been using wgs84 also.
> You can use m.proj to break down the projection into two steps:
Ok, I'm with you. Lets do a couple of steps together.
First the X and Y below are the ACCURATELY CONVERTED STP coordinates for
the original point in aea. I did the conversion to ll from his numbers. So
these are the expected coordinates for the other rounded point.
X (feet) Y (feet) Longtitude Latitude
536507.00 1764928.00 81:53:08.131239W 29:11:20.067269N
By the way, my original estimate was wrong, I'm off by more like 156000
feet. Yikes!!
> My m.proj gives
> 82d22'30.036W 29d11'17.659N
> give (i assumed the ellipsoid wgs84). Does that make sense?
Ok. I got the ellipsoid(s) he is using (he wasn't certain of which but it
is one of the two) grs80 or wgs84. Stephen at FSU works on a number of
projects, so he couldn't remember which one off the top of his head.
I've tried both, so I doubt that this is an issue.
> Note that r.proj nor m.proj will not make datum.shifts (yet), but datum
> differences should not give errors of the magnitude you mention.
Fortunately I now we know we don't have to do datum shifts.
> Also note that the proj parameters for STP projections are statically
> defined in <grass install directory>/etc/state27 and FIPS.code files. I
> have no idea about the accuracy of those formulas. Maybe someone with more
> knowledge about STP would like to check them.
I am not very knowledgeable, but as I understand it, these numbers are
gotten from PROJ.4. Those numbers have been good enough for me to go from
lat/long to stp from gps data, and present it on a map within a couple
foot accuracy.
> Can you dump us your PROJ_INFO for both the input and output location, the
> DEFAULT_WIND for the output location and the cellhd file of the input map
> (a file with the same name as the input map, located in the cellhd
> directory of the input location.) Also please say what your expected STP
> co-ordinates for your test poit are exactly. This would help to do some
> more debugging.
The test point expected results(also in the chart above) are:
X: 536507.00
Y: 1764928.00
NOTE: The original points were rounded for expediance. The resultant
points that were generated from the rounded points were still thousands of
feet more accurate than my conversion.
STP Location:-------------------------
DEAFULT_WIND-
proj: 99
zone: 0
north: 1907628
south: 1657863
east: 784820
west: 473816
cols: 311004
rows: 249765
e-w resol: 1
n-s resol: 1
PROJ_INFO-
proj: tmerc
a: 0.63782064e+07
es: 0.6768657997291094e-02
x_0: 0.1524003048006096e+06
y_0: 0
k: 0.9999411764705882e+00
lon_0: 82dw
lat_0: 24d20'n
Aea Location:---------------------------
DEFAULT_WIND-
proj: 99
zone: 0
north: 576795
south: 569695
east: 564255
west: 557754
cols: 6501
rows: 7100
e-w resol: 1
n-s resol: 1
PROJ_INFO-
name: Albers Equal Area
proj: aea
ellps: wgs84
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572235630
lat_0: 27.4500000000
lat_1: 24.0000000000
lat_2: 31.5000000000
lon_0: -84.0000000000
x_0: 400000.0000000000
y_0: 0.0000000000
Hope this helps and Thanks again,
Matt
