[GRASSLIST:1801] Failure to create FIFOs and /dev (Beta11)!
Lawrence Houston grass at boyd.geog.mcgill.ca
Wed May 2 00:18:42 EDT 2001
GRASS Users:
Sorry if this has been covered previously:
- Makefile fails to create FIFOs (and the "dev" directory) if
  ${INST_DIR}/dev does NOT exist prior to running "make install" (as root)!
- Result is NO Directory, instead a plain file named "dev" who's contents
  are "create_ipcs.sh" (from the Makefile's second copy operation)?
- Source Code 5.0 Beta 11, System VALinux 6.2.3
Lawrence Houston  --  (grass at boyd.geog.mcgill.ca)
