[GRASSLIST:1828] Creating a DEM
michele.rocc at libero.it michele.rocc at libero.it
Fri May 11 04:33:14 EDT 2001
I'm trying to create a DEM from a "scannerized" map, because of the
large amount of feature I thought to extract in some way the contour
lines using r.thin and r.line, then I heard that maybe there is som
problems in doing that (something like r.surf.contour doesn't work fine
yet..).
Well, is my idea possible to do? I know that any line will be
reproduced but I wanted to eliminate manually by v.digit the "not-
contour" lines.
Anyway, even it I decide to copy all contour lines point by point, is
there a working feature in GRASS to create the DEM?
Thanks,   Michele
