[GRASSLIST:1883] Re: r.in.gdal
S. Holl
sholl at gmx.net
Sun May 27 15:33:39 EDT 2001
Markus Neteler wrote:
> On Fri, May 25, 2001 at 10:14:57AM +0200, S. Holl wrote:
> > Hi there
> > I importet several TIFFS (with .tfw-files) with r.in.gdal and let it
> > create a new location with the TIFF coordinates.
> > Everything worked fine, but it seems there is no PROJ-INFO-file in the
> > new $LOCATION.
> > This is needed by r.proj for doing some tranformation.
> > So r.proj cannot transform my TIFFS into a new location.
> > any suggestions and sollutions ?
> > Thanks for your help
> Hi Steph,
> the problem is that the .tif/.tfw files don't contain any projection
> information. If you would have a .proj file as well, r.in.gdal should
> accept it. However, after creating the location by r.in.gdal use
> g.setproj within this new location. It will set the missing information.
> Cheers
> Markus
markus,
g.setproj doesn`t work in xy-locations.
-> XY-location cannot be projected
my tifs should be in GK-location.
is r.in.gdal not able to create GK-locations ?
regards
steph
Stephan Holl
sholl at gmx.net
http://frosch.2y.net
