[GRASSLIST:1890] Re: r.in.gdal
S. Holl
sholl at gmx.net
Mon May 28 16:49:09 EDT 2001
Markus Neteler wrote:
> > > On Fri, May 25, 2001 at 10:14:57AM +0200, S. Holl wrote:
> > > > Hi there
> > > > I importet several TIFFS (with .tfw-files) with r.in.gdal and let it
> > > > create a new location with the TIFF coordinates.
> > > > Everything worked fine, but it seems there is no PROJ-INFO-file in the
> > > > new $LOCATION.
> > > > This is needed by r.proj for doing some tranformation.
> > > > So r.proj cannot transform my TIFFS into a new location.
> > > > any suggestions and sollutions ?
> > > > Thanks for your help
> > > Hi Steph,
> > > the problem is that the .tif/.tfw files don't contain any projection
> > > information. If you would have a .proj file as well, r.in.gdal should
> > > accept it. However, after creating the location by r.in.gdal use
> > > g.setproj within this new location. It will set the missing information.
> > > Cheers
> > > Markus
> > markus,
> > g.setproj doesn`t work in xy-locations.
> > -> XY-location cannot be projected
> > my tifs should be in GK-location.
> > is r.in.gdal not able to create GK-locations ?
> > regards
> > steph
> Hi Stephan,
> o.k. I didn't think of that. So another try:
> Generate a .prj file for your data and generate a new
> location with r.in.gdal which *should* accept this .prj file.
> Here a sample for Gauss-Krueger (hope it is correct):
> PROJECTION TRANSVERSE
> UNITS METERS
> DATUM POTSDAM
> PARAMETERS
> 1.000
> 9 0 0
> 0 0 0
> 3500000
> 0.0
> Please tell me if this helps.
> Markus
Hi Markus,
everything is clear now, but actually I could not handle it with your
sollution. I did it like Frank posted, and everything woks fine. r.proj
did a good job after that ;-)
thanks for your help
steph
Stephan Holl
sholl at gmx.net
http://frosch.2y.net
