[GRASSLIST:2573] Re: grass5 and network connections
Eric G. Miller egm2 at jps.net
Mon Oct 8 16:58:01 EDT 2001
To follow-up:  I should point out that the modifications I told you
to perform will not work if $HOME is an NFS mount.  I suppose I
should look at moving the socket files to /tmp/grass-$USER/ or
some such, since /tmp should always be on a local drive.
Eric G. Miller <egm2 at jps.net>
