[GRASSLIST:2403] symbols
anne-claire serres
anne-claire.serres at thales-is.com
Fri Sep 7 09:18:46 EDT 2001
Hi !
I am using the d.icons command without problem if icons are designed
with the p.icons command by 'cross' in a Unix file. If, still using
p.icons, I answer at the question 'which editor do you want to use?' :
gimp and that I draw a circle with it, when I use d.icons, instead of a
circle, kind of histogramm are drawned. If I use some vector file as
icon, it is the same problem. Is there a way to import symbols as icons
in grass ?
Thank you very much !
Anne-Claire
Type: text/x-vcard
Desc: Carte pour anne-claire serres
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20010907/b7fc2b75/anne-claire.serres.vcf
