[GRASSLIST:2416] more startup woes
Aurelien
aurelien at fractals.be
Mon Sep 10 10:17:38 EDT 2001
First of all, thanks buddies for your answers. Seems like it's hard to
start using GRASS !
I've downloaded the spearfish dataset for grass 5 and put it under /opt
BTW, I had to manually add /usr/local/bin to my PATH. Is this normal ? I
wonder also if I have to source /etc/csh.cshrc and /etc/csh.login
everytime...
Now, if I cd to /opt and do 'grass5 spearfish/PERMANENT', yes, I get a
'GRASS 5.0beta11 >' prompt
There, the terminal tells me I've got several options:
This version running thru the TC Shell (/bin/tcsh)
Help is available with the command: g.help
See the licence terms with: g.version -c
Start the graphical user interface with: tcltkgrass&
When ready to quit enter: exit
Funny thing, if I do g.help, I'm back with the 'vt100 error'. g.version
-c works though (Great !), and exit works also. However, if I enter
'tcltkgrass&', I get the following message:
[1] 747
Mapset <PERMANENT> in Location
<spearfish> GRASS 5.0beta11 >
/usr/local/grass5/bin/tcltkgrass: command not found: wish [3]
What is 'wish' now ?
NOTE: I had launched XDarwin in rootless mode before starting GRASS
thx in advance,
Aurélien
