[GRASSLIST:2460] Compilation problem
    Daniel Tourde
    ted at foi.se
    Wed Sep 19 10:19:54 EDT 2001
Hello,
I am trying to build Grass5pre2 on a RedHat 7.1 box
I use the following command:
./configure --prefix=/opt/grass --bindir=/usr/local/bin
--with-postgres-includes=/usr/include/pgsql
--with-zlib-includes=/usr/include
and I end up with the following error messages:
/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint/Programs/p.map/inter
  mkdir OBJ.i686-pc-linux-gnu
  make -f OBJ.i686-pc-linux-gnu/make.rules
gcc -g -O2  -I/usr/src/redhat/BUILD/grass5.0.0pre2/src/include
-I/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint  -c scan_color.c -o
OBJ.i686-pc-linux-gnu/scan_color.o
-I/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint  -c scan_scale.c -o
OBJ.i686-pc-linux-gnu/scan_scale.o
scan_scale.c: In function `scan_scale':
scan_scale.c:31: `_' undeclared (first use in this function)
scan_scale.c:31: (Each undeclared identifier is reported only once
scan_scale.c:31: for each function it appears in.)
scan_scale.c:31: parse error before `const'
scan_scale.c:31: parse error before `)'
make[3]: *** [OBJ.i686-pc-linux-gnu/scan_scale.o] Error 1
make[3]: Leaving directory
`/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint/Programs/p.map/inter'
make[2]: *** [all] Error 1
make[2]: Leaving directory
`/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint/Programs/p.map'
make[1]: *** [all] Error 1
make[1]: Leaving directory
`/usr/src/redhat/BUILD/grass5.0.0pre2/src/paint/Programs'
GISGEN failure at STEP: src/paint/Programs
GISGEN: src/paint/Programs/p.map.new/cmd - Wed Sep 19 15:50:16 CEST 2001
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
