[GRASSLIST:2464] RPMs of Grass5pre2 for RedHat 7.1
    Daniel Tourde
    ted at foi.se
    Thu Sep 20 03:56:51 EDT 2001
Hello,
I have compiled successfully (thanks for the help...) Grass5pre2 on my
RedHat 7.1 box. I have used a grass.spec file from the package provided
by Intevation (www.freegis.org) for Grass5beta11.
This spec file builds up 4 i386.rpm:
GRASS-ODBC
GRASS-OpenGL
GRASS-postgreSQL
For my first attempt I kept the list of file to be added to the rpms
from Grass5pre11 and I simply compared with the files of Grass5pre2
(Considering that the spec file, copy the files on the destination
directory in anycases, I just add to install and uninstall the i386.rpms
and look at what was left....).
Here is the result:
/opt/grass/grass5/dev/create_fifos.sh
/opt/grass/grass5/bin/d.colorlist
/opt/grass/grass5/bin/d.rgb
/opt/grass/grass5/bin/d.vect.labels
/opt/grass/grass5/bin/r.composite
/opt/grass/grass5/bin/r.his
/opt/grass/grass5/bin/r.param.scale
/opt/grass/grass5/bin/r.weight2
/opt/grass/grass5/bin/s.vol.rst
/opt/grass/grass5/bin/s.what
/opt/grass/grass5/documents/html/d.vect.labels.html
/opt/grass/grass5/documents/html/i.rvi.prediction.html
/opt/grass/grass5/documents/html/i.shape.html
/opt/grass/grass5/documents/html/r.composite.html
/opt/grass/grass5/documents/html/r.fillnulls.html
/opt/grass/grass5/documents/html/r.his.html
/opt/grass/grass5/documents/html/r.in.elas.html
/opt/grass/grass5/documents/html/r.out.elas.html
/opt/grass/grass5/documents/html/r.out.ppm3.html
/opt/grass/grass5/documents/html/r.random.cells.html
/opt/grass/grass5/documents/html/r.rescale.eq.html
/opt/grass/grass5/documents/html/s.sweep.html
/opt/grass/grass5/documents/html/s.what.html
/opt/grass/grass5/documents/env_vars.html
/opt/grass/grass5/documents/projections_supported.html
/opt/grass/grass5/documents/terminology.html
/opt/grass/grass5/documents/tips_and_tricks.html
/opt/grass/grass5/etc/bin/cmd/d.colorlist
/opt/grass/grass5/etc/bin/cmd/d.rgb
/opt/grass/grass5/etc/bin/cmd/d.vect.labels
/opt/grass/grass5/etc/bin/cmd/p.chart
/opt/grass/grass5/etc/bin/cmd/r.composite
/opt/grass/grass5/etc/bin/cmd/r.his
/opt/grass/grass5/etc/bin/cmd/r.param.scale
/opt/grass/grass5/etc/bin/cmd/r.weight2
/opt/grass/grass5/etc/bin/cmd/s.what
/opt/grass/grass5/etc/bin/cmd/s.vol.rst
/opt/grass/grass5/etc/geo.reg
/opt/grass/grass5/etc/geo.point
/opt/grass/grass5/etc/frame.list
/opt/grass/grass5/etc/lister/dig
/opt/grass/grass5/etc/lister/site_lists
/opt/grass/grass5/scripts/r.fillnulls
/opt/grass/grass5/scripts/v.area2line
/opt/grass/grass5/scripts/v.region.sh
/opt/grass/grass5/scripts/v.cutregion.sh
/opt/grass/grass5/scripts/v.in.mapgen.sh
/opt/grass/grass5/tcltkgrass/main/tksys.tcl
/opt/grass/grass5/tcltkgrass/module/d.measure
/opt/grass/grass5/tcltkgrass/module/r.in.gdal
/opt/grass/grass5/tcltkgrass/module/v.in.dxf
/opt/grass/grass5/tcltkgrass/module/v.surf.rst
/opt/grass/grass5/man/man1/d.vect.labels.1
/opt/grass/grass5/man/man1/i.shape.1
/opt/grass/grass5/man/man1/i.rvi.prediction.1
/opt/grass/grass5/man/man1/r.composite.1
/opt/grass/grass5/man/man1/r.fillnulls.1
/opt/grass/grass5/man/man1/r.his.1
/opt/grass/grass5/man/man1/r.in.elas.1
/opt/grass/grass5/man/man1/r.random.cells.1
/opt/grass/grass5/man/man1/r.out.elas.1
/opt/grass/grass5/man/man1/r.out.ppm3.1
/opt/grass/grass5/man/man1/r.rescale.eq.1
/opt/grass/grass5/man/man1/s.sweep.1
/opt/grass/grass5/man/man1/s.what.1
Now here is my question. Where do I put these files considering that I
want to keep the nature of the i386.rpm files?
GRASS-ODBC
GRASS-OpenGL
GRASS-postgreSQL
I would be tempted to put all of them in GRASS but I am afraid it would
be a too simple solution.... :)
Thanks for any help or advice
Best regards
			Daniel
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
