[GRASSLIST:2483] Re: Trouble with handling of my path by grass
Eric G. Miller
egm2 at jps.net
Wed Sep 26 00:48:14 EDT 2001
On Wed, 26 Sep 2001 00:07:03 -0400, "ted byers" <ted.byers at sympatico.ca> wrote:
> I am running grass on xfree+cygwin on NT, and it all seems to be
> working, as
> far as I have been able to ascertain so far.
> However, after I have started grass, and selected a dataset, I see the
> meu
> appear, as well as a welcome screen in the window in which I started
> grass,
> but that welcome text is immediately followed by three errors from bash
> complaining about invalid exported symbols. I have three spaces in my
> path
> (from that portion of the path created by NT for user installed
> applications), and I get precisely three errors. The text of the errors
> shows that export is splitting the path into three parts at the location
> of
> the spaces.
This is the problem. Try editing Init.sh down where there a line that
looks like:
echo "export PATH=$PATH" >> $bashrc
to
echo "export PATH=\"$PATH\"" >> $bashrc
There may be a few other places where some quoting needs to be done
so spaces are handled. Maybe some other CygWin users want to look
at this -- Note underscores or hyphens make good separators for file
and directory names!
> If I open a window in which bash is running, and call "echo $PATH", I
> get
> exactly the right output. If I then call "export PATH", it seems to
> behave
> properly as I get no output, but if I call "export $PATH", I get the
> same
> errors that I see when I srtart grass.
There is no "export $PATH" that I can see...
> Also, is it my imagination, or does Init.sh rewrite .bashrc toward the
> end
> of the script? If it is rewriting .bashrc, my question is why, and
> might
> the errors I am seeing be caused here?
GRASS is fooling with the shell it's invoking, but it is not modifying your
~/.bashrc. Do a "ls -a" in one of your mapsets, and you'll see the file
it has written. You can add some niceties by putting things in
~/.grass.bashrc. I like color listings for instance...
Eric G. Miller <egm2 at jps.net>
