[GRASSLIST:2485] v.in.shape problem
Daniel Tourde
ted at foi.se
Wed Sep 26 07:32:51 EDT 2001
Hello,
I am trying to import a shapefile map using the v.in.shape function.
I have the following files:
st97_d.dbf st97_d.sbn st97_d.sbx st97_d.shp st97_d.shx
and I use the following commands:
Mapset <PERMANENT> in Location <Sweden>
GRASS 5.0.0pre2 > v.in.shape -l in=st97_d.shp
Attributes available in st97_d.shp
AREA
PERIMETER
ST97_D_
ST97_D_ID
KKOD
KATEGORI
SRIKT
GRUPP
GRASS 5.0.0pre2 > v.in.shape -b in=st97_d.shp
BOUNDS OF REGION ARE:
West: 1523190.000000
North: 6584195.000000
East: 6506040.000000
South: 1596933.250000
and finally:
GRASS 5.0.0pre2 > v.in.shape verbose=9 in=st97_d.shp attribute=AREA
"st97_d.shp" successfully opened
ERROR: Point map import not now supported by this module: use s.in.shape
I don't understand this error. What am I supposed to do now?
If I use s.in.shape, I import site but apparently nothing else. How the
problem can be solved?
Daniel
Daniel TOURDE E-mail : daniel.tourde at foi.se
Tel : +46 (0)8-55 50 43 44
Cellular : +46 (0)70-849 93 40
FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden Fax : +46 (0)8-25 34 81
