[GRASSLIST:2508] Which projection?
    Gordon Keith
    gordon.keith at marine.csiro.au
    Fri Sep 28 02:05:50 EDT 2001
I have a gridded data set I want to read into grass, but I'm not sure
which projection to use. The header for the data contains the following
information:
Datum: WGS84
Half axis: 6378137.0000000
Flattening: 1/298.25722356300
Coordinate system: Lat/Long
Latitude min.: -42.78126745
Longitude min.: 148.31130940
Latitude max.: -42.58820665
Longitude max.: 148.49252740
Latitude cell size: 30.00 meter
Longitude cell size: 30.00 meter
I can get the same data output using a different coordinate system with
the header:
Datum: WGS84
Coordinate system: merc
Y min.:  -5248244.68
X min.:   4966111.48
Y max.:  -5219451.16
X max.:   4985106.57
I'm not very familar with projections and don't understand the
significance of the half axis and flattening terms.
The data is gridded, but the grid coordinates don't follow lines of
latitude and longitude, so I haven't had good results reading the data
into grass using a latitude longitude projection.
Could someone please suggest the projection and information I will need
to create it in grass?
I will need to work with this data in latitude/longitude coordinates.
Does this mean I will have to reproject (r.proj) the data into a
latitude longitude projection, if I get it into grass successfully?
Thanks in advance
Gordon
