[GRASSLIST:3402] Re: Packages not found when compiling under Linux Mandrakee
Bernhard Reiter
bernhard at intevation.de
Mon Apr 1 12:30:39 EST 2002
On Mon, Apr 01, 2002 at 04:49:21PM +0000, pa paras wrote:
> Hi all. I'm running into problems when compiling grass
> 5.0.0pre3 under mandrake 8.2. The distribution comes
> with postgres, gdbm and freetype2 but configure can't
> find the packages and stops the install.
> How can I show where the packages are while configuring?
Did you install the development header?
Usually they are called "-dev".
If you build GRASS 5.0.0pre3 you can tell it to
not use the packages or use non-standard locations.
Check ./configure --help for various options.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020401/a55dfd64/attachment.bin
