[GRASSLIST:3428] Re: Does precompiled linux binaries include all packages?
Moritz Lennert
fa1079 at qmul.ac.uk
Thu Apr 4 02:38:30 EST 2002
pa paras wrote:
> Hi all. I eventually gave up trying to compile the src
> myself under mandrake (I intend to compile all available
> modules. I'll give it a try later on...).
> So I installed the precompiled binaries. It runs fine
> but postgres commands seem to be unavailable. Should
> I install the grass-postgresSQL-interface rpm now?
> (I can´t recall where I got it! but it's version 5 too)
> What about the OpenGL rpm?
The precompiled version does not contain all packages, so, yes, you can
install the rpm's of the modules that are missing (which you probably
got from www.freegis.org).
Moritz
