[GRASSLIST:3451] Re: seeking advice on improving results with s.surf.rst
Steve Trick
TrickSG1 at Cardiff.ac.uk
Fri Apr 5 14:38:54 EST 2002
On 25 Mar 2002 at 12:02, Neil Ripley wrote:
> The problem I have is that the segment edges are very apparent in the
> results I am getting from s.surf.rst. I am not getting a smoothly
> continuous surface as I expect I should. Instead I have clear and
> distinct breaks that coincide with the segmentation boundaries.
Hi Neil,
I had similar problems getting good interpolation results using
contour lines data.
Better results were achieved using the following method (based
on advice from Helena Mitasova).
Create an interpolated surface from your contour data, using
s.surf.rst, with the default parameters. Then run r.random on
this surface to create some additional 'spot heights'. Then add
those random points to your original sites file that you used to
generate the first surface. Then run s.surf.rst again. Since
s.surf.rst is more used to using distributed point data, you
should get better results.
Even though this method worked for me, I decided to try some
alternative routes. I managed to get some very good results
using the Surfer program, which I was fortunate to have access
to. I exported my GRASS sites file to an ascii file that Surfer
could read. Surfer can generate interpolated sufaces using a
wide range of methods. I found the 'natural neighbour' method
worked best with contour data. You can then import the Surfer
raster back into GRASS using r.in.ascii, using the -s switch.
Hope this helps
Steve
Steven Trick BA MSc
School of History and Archaeology
Cardiff University
PO Box 909
Cardiff
Wales
CF10 3XU
email: TrickSG1 at cf.ac.uk
mob: 07799897107
http://www.cardiff.ac.uk/hisar/people/st/
------ Petition for a Software Patent Free Europe:
http://petition.eurolinux.org/index_html?LANG=en
