[GRASSLIST:3507] Re: Grass Installation
Bernhard Reiter
bernhard at intevation.de
Fri Apr 12 05:44:37 EDT 2002
On Fri, Apr 12, 2002 at 09:56:08AM +0100, Neil.Murphy at axa.ie wrote:
> I am a first timer to GRASS .I downloaded version 5.0 and attempting to
> install.
Which version exactly?
> command ./configure produced the following error " unable to locate curses
> lib"
Check the options of configure,
which you can get by issuing: ./configure --help
Make sure that the development header of a curses library are installed
on your system. If you are not sure what this means, ask your system
administrator or give more details about your system.
Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020412/2301b4d7/attachment.bin
