[GRASSLIST:3518] [r.thin] doesn't seem to converge to zero
    kuszinger at giscom.hu
    Mon Apr 15 08:29:47 EDT 2002
Hello!
I'm Robert and new to the list. I'm using grass (5pre3)
for two days. I used ARC/INFO, ERDAS, Mapinfo an ER Mapper before,
however I liked ARC/INFO the most. But now I found that GRASS
is somehow similar to the ARC/INFO unix versions I used a lot.
(The new ARC/NOF is annoying, slow, etc.)
While I was experimenting I tried to generate countour line
vectors based on a paper map sheet (Hungarian National Survey,
Topography 1:100000).
With color manipulations in GIMP I extracted the contour lines
on the scanned sheet.
I converted to B/W and imported into GRASS.
(image size is 6200 x 4000 or so)
When I ran <r.thin> the number of removed points was
something like this (approx.):
1.st path
825000
2.
340000
3.
124000
4.
678000
5.
38700
6.
36200
7.
35788
8.
35788 (!)
9.
35787
..... At this point I killed the process.
It took so much time and it did not seem to cenverge anymore.
Is it a  bug? Or is the drawing 'too' complicated?
What could be the problem?
Backgound is value is 0 and lines have value 1,
very dense lines usually 2-4 pixels wide.
(Finally I'm planning to convert to vector,
assign height labels and generate a DTM
finally)
Any help welcome
thank you
Robert
