[GRASSLIST:3527] Re: g.select.pg
Markus Neteler
neteler at itc.it
Tue Apr 16 09:21:10 EDT 2002
On Tue, Apr 16, 2002 at 02:53:50PM +0300, orkun wrote:
> Hi
> This is the problem I encountered:
> **** /usr/local/grass5/tcltkgrass/module/g.select.pg: interface_build:
> command not found ****
> although I made necessary changes to /usr/local/grass5/etc/Init.sh (I included addon path for g.select.pg).
> this problem took place.
> What might I miss ?
I assume that you use the tar.gz-packaged Linux version (not the RPM).
Unfortunately that version does not contain the PostgreSQL modules.
Maybe a user is willing to package the PostgreSQL modules for you and
send them, or you switch to the RPM.
Kind regards
Markus Neteler
