[GRASSLIST:3570] Re: (ps.map) how to print map?
Radim Blazek blazek at itc.it
Tue Apr 23 06:05:17 EDT 2002
On Tuesday 23 April 2002 10:45 am, Valentin Podlovchenko wrote:
> when I print map to postscript file with ps.map, Grass always changes
> scale
> to fit on a4 paper size even when I say larger scale. Although if I
> give small scale, map created with ps.map has correct scale.
> How to print larger map (at given scale)? And may someone advise me how
> to print large postscript document on multiple sheets of paper on linux.
> Thanks,
You must set the region you want to print first.
Radim
