[GRASSLIST:3595] Linux Startup Problem
Kirk Schmidt kirkschmidt at auracom.com
Fri Apr 26 11:06:27 EDT 2002
Thanks for the help with the Startup Problem .  The XF86Config file
contained two default paths for fonts (generated with Xconfigurator)
Eric, you are right,, I should keep my OS questions out of the Grasslist
Thanks to All
Kirk
