[GRASSLIST:4239] Re: compiling Grass5pre5 on Linux
Thomas Dewez
thomas.dewez at brunel.ac.uk
Wed Aug 7 12:22:50 EDT 2002
Ulrich and others,
I am precisely following your tracks (GD not found, tried compiling GD but
it couldn't find something else, so I disabled it). ODBC seems to be present
on my system but not where configure seems to be looking. Also tcl and tk
are not found, though they are there. I can see them.
Could somebody state how things should be written down for customizing the
configure script? I mean, if I want to include a package whose assumed path
is not correct what do I do? There's the include thingy and the lib thingy
that need be specified, but in what order? Not sure what the include and lib
must contain to work. I know it is basic but would appreciate a quick
explanation.
Could you present an example?
Thanks
Thomas
----- Original Message -----
To: <GRASSLIST at baylor.edu>
Sent: Wednesday, August 07, 2002 2:03 PM
Subject: [GRASSLIST:4236] Re: compiling Grass5pre5 on Linux
> On Wed, Aug 07, 2002 at 02:53:06PM +0200, Ulrich Leopold wrote:
> > what do I need the include files (*.h etc.) from GD and also FFTW for.
Are
> > they necessary for building a functional GRASS unless I do not want to
> > develop additional programs?
> Hi Ulrich,
> you can disable support using the '--without-package' flag.
> configure --without-fftw --without-gd [...]
> FFTW is used for
> src/imagery/i.fft
> src/imagery/i.zc
> src/raster/r.surf.fractal
> src.contrib/CERL/imagery/i.shape
> and GD for
> src/display/devices/PNGdriver
> If you disable FFTW and/or GD, above modules won't compile. The 'rest'
> will be functional.
> Hope this helps,
> Markus
> > Lowell Filak wrote:
> > > /usr/include/gd.h
> > > rpm -i gd-devel-1.8.x-x
> > > HTH
> > > The following message was sent by Ulrich Leopold
<uleopold at science.uva.nl> on Wed, 07 Aug 2002 13:05:08 +0200.
> > >>HI,
> > >>I am trying to compile Grass5pre5 on RedHat 7.2 Linux.
> > >>When I start ./configure I get the following message:
> > >>checking whether to use GD... yes
> > >>checking for location of GD includes...
> > >>checking for gd.h... no
> > >>configure: error: *** Unable to locate GD includes.
> > >>What does it exactly mean. And what is ./configure looking for? And
where is
> > >>this usually located?
> > >>Ulrich
> > >>__________________________________________________
> > >>Ulrich Leopold MSc.
> > >>Department of Physical Geography
> > >>Institute for Biodiversity and Ecosystem Dynamics
> > >>Faculty of Science
> > >>University of Amsterdam
> > >>Nieuwe Achtergracht 166
> > >>NL-1018WV Amsterdam
> > >>Phone: +31-(0)20-525-7456 (7451 Secretary)
> > >>Fax: +31-(0)20-525-7431
> > >>Email: uleopold at science.uva.nl
> > >>http://www.frw.uva.nl/soil/Welcome.html
> > >>Check us also out at:
> > >>Netherlands Centre for Geo-ecological Research
> > >>http://www.frw.uva.nl/icg
> > Ulrich Leopold MSc.
> > Faculty of Science
> > NL-1018WV Amsterdam
