[GRASSLIST:4254] Segmentation fault while using v.proj, r.proj
Xueming Wu xwu at cse.unl.edu
Thu Aug 8 14:18:43 EDT 2002
Greetings,
I tried to use v.proj and r.proj to convert projection for
some data. But It reported "Segmentation fault". Do anybody
know what problem is? My Grass is Grass 5.0.0pre4 on RedHat7.3.
I have installed PROJ4.40. And I have also tried PROJ4.3.3 and
PROJ4.4.5. The same error message was prompted.
Thank you for your help. I appreciate.
Xueming
