[GRASSLIST:4287] Re: more gdal help!
Glynn Clements glynn.clements at virgin.net
Tue Aug 13 22:26:33 EDT 2002
Kevin Slover wrote:
> I am not sure, of course, what the usefullness of the r.composite tool.  It
> fails to correctly display the image I was shooting for.  I know in other
> programs (manifold) that you use a composite type function to piece together
> the rgb values.
The purpose of r.composite was to counter the complaints which arose
when I removed the composite map generation functionality from several
programs (e.g. d.his, r.in.*).
Some people seemed to want that functionality, although I still
haven't discovered why.
Glynn Clements <glynn.clements at virgin.net>
