[GRASSLIST:4384] Nviz and Debian again
michele.rocc at libero.it michele.rocc at libero.it
Tue Aug 27 04:07:11 EDT 2002
>michele.rocc at libero.it wrote:
>> > You need to do one of the following:
>> > 1. If your X server supports GLX, but it isn't enabled, then enable
>> > it; for XFree86 4.x, you need the line:
>> >     Load "glx"
>> > in the "Module" section of XF86Config.
>> > 2. If your X server doesn't support GLX, replace your X server with
>> > one which does, or
>> > 3. Replace your GL library (libGL.so.*) with one which implements
>> > OpenGL on the client side (e.g. Mesa), eliminating the need for the X
>> > server to support GLX.
>> Actually I am using Mesa but still I have the problem, maybe there is
>> some particulary extension of Mesa that I have to install?
>The error message indicates that you are not using Mesa. You may have
>Mesa installed, but it isn't being used. Mesa is purely client-side;
>it does not require the GLX extension, it will not make any use of the
>GLX extension if it does happen to be present, and it will not
>complain about the fact that the X server lacks the GLX extension.
>Check for the existence of libGL.so.* in /usr/X11R6/lib; if any such
>files exist, rename them or move them so that they aren't found.
In Debian package list I didn't found any openGL... library nor
libMesaGL... but only xlibmesa...
I found in /usr/X11R6/lib the package libGL.so.* I renamed it and
created a link named libGL.so.1 to libOSMesa.so.3.3, because
there is no library called libMesaGL.so, but this don't works.
I search for libMesaGL in Debian site within the packages
page with no results, and a general search in the web point me
only to RPM packages;
Searching in Debian packages page again, only with "mesa" word
I found xlibmesa3 package that is the one I installed and it
supply the lib libGL.so.1 and I think is the one I found
in /usr/X11R6/lib dir.
So I thougt that in this Debian System I'm using (3.0 woody)
libMesaGL was called libGL.so.1, but at this point it comes
out the strange message that requires GLX extension and this
indicates that I'm using openGL...
I think I need some help! :)
Thanks, Michele.
