[GRASSLIST:4402] error reading vector file with grass-jni
Allard, Yannick (EXP) yannick.allard at lmco.com
Thu Aug 29 12:04:04 EDT 2002
I've got the following error when I'm trying to use the following command
with grass-jni : Vect_open_old( ..., ... ).
The error I got : ERROR : System not initialized. Programmer forgot to call
G_gisinit().
This error is strange since I'm using function of the libgis object without
any problem. The libvect is initialize with it  like that :
libvect lv = new libvect( libgis_object );
and I'm able to call the following method : lv.Vect_set_open_level( ... );
but the error is thrown every time i'm trying to call lv.Vect_open_old(
vector, mapset );
Does anyone have any idea of what should i do to correct this....or is there
a step I'm missing to open the vector file...
thanks in advance
Yannick Allard
Ph.D student, Universite de Sherbrooke
R&D senior associate member
Lockheed Martin Canada
6111 Royalmount, Montreal
(514) 340-8310 #7776
