Hi, I need to copy a vector map on an external location. g.copy shows me only maps in the current location mapsets. Can I use the unix command (cp) with files in dig* folders? I tried with v.out.ascii and v.in.ascii. But this it is a too long way (later I need run v.support and vector map is very big) Thanks, Miguel
